Sucralfate is hurting my teeth! Anyone used the tablet form?
AliaAvery
Re: Sucralfate is hurting my teeth! Anyone used the tablet form?
Post by AliaAvery »
If your teeth are still feeling sore, it’s worth checking in with a dentist. When I had a similar issue, my dentist suggested fluoride treatments and a good sensitivity toothpaste, and it really made a difference. If the problem sticks around, someone like could help figure out what’s going on and give you some options to protect your teeth while you’re dealing with the stomach stuff. Balancing both can be tricky, but it’s doable.
