Re: How accurate is the HP breath test. Thanks
Posted: Fri Jan 13, 2012 4:28 pm
hi,
breath test is pretty accurate. stool test is just a double confirmation. Did you stop taking any acid reduction medication for at least 3 weeks prior the breath test? The acid reduction medication will interfere with the test kit and give false negative result. I would just repeat the breath test again. see how negative is negative.
