C14 UBT and opinions needed
Re: C14 UBT and opinions needed
If you prepared to see a gastroenterologist, then endoscopy is the topic of discussion. You can ask him all the questions about PPI, different brands of PPI, the measurement of your gastric pH, the biopsy and histology.
PPI has been on the market for many years and is generally safe. The side effect is osteoporosis. But that will happen if you take it for years.
Ice006
Post by Ice006 »
Saw a GP today, seemed like a good/great guy, but didn't really get a better stance on things. He referred me to a Gastroenterologist.
He said I can take the H. Pylori meds, and all the other supplements the other Doctor recommended, but basically it's up to me. He said if I can't decide maybe see the Gastroenterologist first and go from there (that's a fair call) after seeing what he has to say. I did ask about another breath test, but I am guessing he would rather I take the meds due to my symptoms and see what happens.
A lot of the regular GPs/Doctors keep banging on about my current diet (Ketogenic), but they just don't seem to listen that I was worse off when eating a ton of carbs. When I eat carbs I can't seem to stop as I am never satisfied. It's like I am getting zero nutrition from them and only a short burst of energy due to the sugar that doesn't last long. That's not the best way to go long term. My energy sucked before, and my gut issues were even more prevalent back then (more gas/bloating etc.).
What should I ask the Gastroenteroligst that he might not check for if I don't request it as far as H. Pylori and other possible bacterial issues? I will ask about H. Pylori and/or if he thinks it could be a low stomach acid issue.
Helico_expert wrote:
Wed Apr 06, 2022 8:30 am
Didn't see this message until after I posted my reply above. Thanks.
I'll also ask some stuff from this previous post of yours :
Tue Mar 29, 2022 2:39 pm
I wouldnt recommend antibiotics without proper diagnostic. mis use of antibiotics will only lead to more antibiotic resistance.
Breath test is most accurate when the stomach is acidic. The H. pylori treatment always come with PPI and antibiotics. The PPI will stop the acid secretion and help the antibiotics work better. sometimes, the patient will be asked to continue PPI until the symptoms are relieved.
Therefore, you'll need to stop PPI and antibiotics for at least 2 weeks before the breath test.
The upper gastro endoscopy will send a tube down your throat to have a look around for abnormalities. The gastroenterologist will take a few biopsies for histology examination. Some gastric juice can be extracted to check for acid pH. However, this is not a common procedure and can be done upon request.
Interestingly, iron deficiency is associated with H. pylori infection. There are reports of iron level back to normal after H. pylori eradication.
I'll ask and PPIs and also about this Gastic Juice extraction as that sounds like a good idea if I end up going ahead with an Endoscopy after seeing him. I'll ask about the Iron deficiency too. The number might not be low, low, but when eating mostly lamb/beef, I feel the number was too low. Doesn't make sense to me. Something is causing it to be low as it's definitely not from a lacking diet.
Look forward to reading your gastroenterology report. good luck.
Ice006
Post by Ice006 »
Hi Helico_Expert,
I just wanted to ask another couple more questions.
If I wanted to check stomach acid, that's something I have to request?
Also, I have kind of decided to take the Nexium HP-7 (I think this is what was prescribed) antibiotics before going to the Gastroenterologist just to see if it makes any difference. I figure if I can take them beforehand, I can tell him if it made any difference. Question is, if I do have H. Pylori, how long after taking would you notice a difference? I want to reschedule my appointment as it's for next week (I am assuming that won't be enough time to see if the antibiotics worked?). Should I change it to 3-4 weeks after taking them?
since you are definitely going to do the endoscopy, why dont you take the antibiotics after that?
the antibiotics and PPI will affect the histology and give false negative results.
and yes, stomach acid is not a routine check. So you will need to request your gastroenterologist to check it.
Ice006
Post by Ice006 »
Sun Apr 17, 2022 2:39 pm
Thanks for the quick reply. If you celebrate it, hope you're having a great Holidays.
Well, this was my train of thought - I was kind of thinking if the antibiotics work, then maybe I could skip the endoscopy all together. I kind of don't like the idea of a colonoscopy or endoscopy. The person I spoke to on the phone when going through all the details said I'd likely have both done by the Doctor, and I am sure she said they put you under a few hours for it? Is that correct? I thought I'd be awake during it. If so, all that has put me off a bit. Is an endoscopy done through the nose or mouth?
Also, when you say "histology" what does that mean? I'm not familiar with the terminology. Will antibiotics affect the test results even if I do have an endoscopy or colonoscopy 4 - 8 weeks after taking them?
Alright, thanks. I'll ask for this. Not sure if you think I need it, but I kind of want to if possible. Is it a procedure separate from the Endoscopy, or can it be done at the same time?
you'll probably going to be asleep and not remember anything during the colonoscopy and endoscopy. So dont worry about it.
histology is when the biopsy is taken to the laboratory for examination.
Ice006
Post by Ice006 »
Mon Apr 18, 2022 2:58 pm
Alright, thanks. With the Histology still be affected if I didn't do the Endoscopy for at least 4-8 weeks after taking them? That's pretty much the last thing I'll ask for now.
If you are over 50 year old, then you should get an endoscopy done, as a baseline reference. In case you need another endoscopy done when you are 60 or 70, then you have something to compare to and see how much worse it have become.
if you are young, around 30-50, mild symptom, then endoscopy is optional. However, if the doctor suspect that you have an ulcer, or have family history of gastric cancer, then endoscopy is still recommended.
if you decided to take antibiotics and PPI, then you'll need to wait for at least 4 weeks before you go ahead for endoscopy.
these are the scenarios
Scenario 1.
you have HP and the treatment works.
your endoscopy would see some gastritis. histology will show inflammation retreating. no HP will be since when special stain is used.
Scenario 2.
you have HP and the treatment failed.
your endoscopy would see some gastritis. histology will show active inflammation. HP can be since when special stain is used.
Scenario 3.
You dont have HP. with or without treatment is the same.
your endoscopy may see gastritis. histology may see a bit of inflammation. no HP will be since when special stain is used.
Ice006
Post by Ice006 »
Tue Apr 19, 2022 2:26 pm
I'm in this age range.
Scenario 1.
Scenario 2.
Scenario 3.
"HP can be since when special stain is used" What does this mean? I don't understand the wording.
So basically, looking at what you're saying, if I'm understand correctly, it's going to change the histology if I take the antibiotics even if I get an endoscopy done 4-8 weeks after taking them?
Also, for scenario 3, is that if I don't take the antibiotics and don't have HP, or is that scenario if I take the antibiotics, but don't have HP?
Thanks a lot for replying. Really appreciate all the awesome help you've given me so far.
