Stool tests that detect the urease protein rather than the virulence proteins?
H.pylori bacteria in the stomach will pass through the bowel and parts of the bacteria will end up in the feaces. To detect the bacteria a feces sample (only 1 or 2 grams is required) is refrigerated and sent to the lab. In the lab antibodies are used to show up presence of bacter (called ELISA testing). These tests can be made in a dipstick form for near-patient diagnosis. the accuracy of these tests varies but is about 90%. This is a test for ACTIVE CURRENT INFECTION so it can be used after treatment to see if H.pylori is gone. It is also an easy one for little children as no needle is required and no fasting or other preparation of the patient needs to be done.
Alfred001
Post by Alfred001 »
Does anyone know which brands of stool tests detect urease proteins, rather than virulence proteins such as VacA and CagA? Or do you know where I might be able to find that information out?
Re: Stool tests that detect the urease protein rather than the virulence proteins?
Do you want to consider breath test?
Return to “Faeces Antigen Tests (stool samples)”
