Are there any clinical labs that perform C14 UBTs near Dallas, Texas, USA?
asnopy
Post by asnopy »
Are you aware of any clinical labs that do the C14 urea breath test (UBT) around Dallas, Texas, USA?
I inquired with Quest Diagnostics, LabCorp, and Clinical Pathology Labs, and all three said they only offered the C13 UBT, which is apparently less accurate.
Thanks!
Re: Are there any clinical labs that perform C14 UBTs near Dallas, Texas, USA?
You can try contact the following
https://www.trimedamericas.com/
otisjami
Post by otisjami »
For a more specific search, you might want to check with local hospitals or nuclear medicine departments, as they might have the necessary facilities for the C14 UBT. Alternatively, consulting a gastroenterologist in the Dallas area could lead to recommendations for specialized labs that perform this test. Additionally, university medical centers and research institutions might offer the C14 UBT as part of their diagnostic services. Strands NYT
branwenarianwen
Post by branwenarianwen »
I can truly sympathize with your situation as you struggle to find a clinic that offers the test you need. This can be very stressful and frustrating. Personally,bitlife I feel that having an accurate test is very important in the treatment of your illness, and I hope you find a place to do the C14 UBT soon so that you can address your health concerns.
blockblast
Post by blockblast »
The C14 urea breath test (UBT) is a diagnostic tool used to detect Helicobacter pylori (H. pylori) infections. While it's known for its accuracy, availability can vary by location. In the Dallas, Texas area, several facilities offer H. pylori breath testing, though they may primarily provide the C13 urea breath test.
villagetunic
Post by villagetunic »
Helico_expert wrote: Wed May 22, 2024 9:04 am You can try contact the following
https://www.trimedamericas.com/slope
Check local hospitals or nuclear medicine departments for C14 UBT facilities for a more focused search. A Dallas gastroenterologist may recommend specialist laboratories for this test. University medical facilities and research institutions may add the C14 UBT to their diagnostic offerings.
Dustin21
Post by Dustin21 »
asnopy wrote: Tue May 21, 2024 9:53 am Are you aware of any clinical labs that do the C14 urea breath test (UBT) around Dallas, Texas, USA?
I inquired with Quest Diagnostics, LabCorp, and Clinical Pathology Labs, and all three said they only offered the C13 UBT, which is apparently less accurate.Beautifulideas.in
Thanks!
I'm also looking into testing options right now. You mentioned that the C13 test is less accurate, is that something your doctor told you, or did you find specific research on it? My gastroenterologist seems to prefer C13 because it's non-radioactive, but I want to make sure I'm not missing something regarding sensitivity.
both C13 or C14 are accurate. They are both based on the same principle, just different isotopes.
However, the accuracy can be affected if your breath is not collected correctly.
lifeiyu123741
Post by lifeiyu123741 »
LabCorp’s H. pylori UBT is explicitly ^13C-based (detects ^13CO2).pokepathtdgame
