New here
Kari1023
New here
Post by Kari1023 »
I was diagnosed with H Pylori last fall. The Prevpac did not help at all. After the second treatment which was protonix, pepto, tinidazole, and another antibiotic of which I cannot remember, I felt like a whole new person (I ate a whole jar of Manuka honey during this time too). I had energy, I wasn't belching after ever thing I ate, the ache in my back and under my arm went away.
Shortly after finishing the round, the symptoms starting coming back. I waited the prescribed time for the breath test, which resulted in a negative.
I got a renewed prescription for the protonix, which helps but does not help 100%. I've had a gall bladder ultra sound which was negative. I recently had an endoscopy, which showed a polyp that was confirmed "chronic gastritis". Based on that result, is it possible I still have H Pylori? Last week, I ate a meal that was potato encrusted salmon, baked potato, salad, green beans. I ate a very small portion and then was up half the night in pain and profusely belching.
I am scheduled for a gall bladder HIDA scan in 2 weeks. I have been insistent on checking it out because my mother had similar issues for years and had her gallbladder removed as an emergency last summer (she had pancreatitis) and my grandmother died of an infected gall bladder-she also belched incessantly.
I gather we are all in the same boat and have the same questions....this is frustrating. Based on the "chronic gastritis" polyp diagnosis, is it possible I still have h pylori?
Re: New here
during your endoscopy, your specialist should have performed a CLOtest. that will tell on spot if you are still infected with H. pylori. Nevertheless, if your breath test is negative, I believe you are no longer infected. You can ask for a second breath test from different GP just to make sure your previous one is not a false negative. if you are taking PPI, breath test will show negative.
gastritis takes time to heal. if you are previously infected, and very recently cured, your gastritis will slowly subside and will slowly go back to normal. So, I suggest you stop all drugs that will reduce stomach acid for 2 weeks. go and seek second opinion (any GP will do). repeat your breath test. that will confirm your previous diagnosis.
