Mastic gum burn!!!!
Yukilo
Re: Mastic gum burn!!!!
Post by Yukilo »
I believe that the elevated stomach acid is the cause of this. Some persons may experience heartburn and stomach discomfort as a result of mastic gum stimulating their stomach acid production.
run 3
Donatella
Post by Donatella »
If mastic gum is having an antimicrobial effect, you could be experiencing a die-off reaction (Herxheimer reaction), which can cause temporary worsening of symptoms as harmful bacteria are killed off strands hint
andreeone23
Post by andreeone23 »
I followed your helpful advice and it worked for me. cookie clicker
Sophian
Post by Sophian »
While mastic gum may help with oral health and potentially combat issues like H. pylori, the discomfort you're experiencing suggests that it might be aggravating your digestive tractslope. It’s important to listen to your body; if the irritation persists, consulting with a healthcare professional might provide more tailored guidance.
