For how long to take PPI after finishing antibiotic
Re: For how long to take PPI after finishing antibiotic
I am not familiar with UK system. But you can check this online chemist
https://www.expresschemist.co.uk/produc ... o-12x.html
AMERC
Post by AMERC »
Thanks but not available in the UK
Can I do the blood test for h pylori whilst on omeprazole 20mg or could it give me a false negative or positive.
This just you confirm that I had it rather than if it has been eradicated
you can do multiple blood tests and see the level of antibody against HP. If the concentration is stable every 3 months, then you are still infected. If the concentration gradually reduce every 3 months, then you are free of H. pylori.
AMERC
Post by AMERC »
Can the symptoms get worse after the eradication therapy which what seems to have happened in my case.
Usually when after HP eradication (for real), then the inflammation will slowly go away and the condition will improve.
Sometimes, the stomach is trying to readjust to a new environment where there is no H. pylori, the symptoms (such as reflux) will temporarily got worse and then improve.
AMERC
Post by AMERC »
Helico_expert wrote: Thu Dec 17, 2020 9:15 am you can do multiple blood tests and see the level of antibody against HP. If the concentration is stable every 3 months, then you are still infected. If the concentration gradually reduce every 3 months, then you are free of H. pylori.
Thanks. Just to confirm that being on ppi should not affect the blood test results
PPI will not affect blood test result
AMERC
Post by AMERC »
Helico_expert wrote: Fri Dec 18, 2020 8:13 am Usually when after HP eradication (for real), then the inflammation will slowly go away and the condition will improve.
Thank you Helico Expert
Typically how long does this readjustment takes. I am into my 8th week after finishing the triple therapy treatment. The acidity symptoms are still ongoing some days more than others. Trying to control it with omeprazole 20mg daily.
My acidity started in June but with omeprazole had gradually bought under control such that I was of ppi for 12 days before endoscopy in October sometime unthinkable now. Post therapy treatment things seems to have gone really backwards
Is it possible for h pylori to cause over acid production but not cause any gastritis or inflammation? Have you come across such cases,?
a very good question. We have not seen a case where H. pylori does not cause inflammation. But perhaps we have not examine healthy people to see if their H. pylori causes inflammation. In almost every case, only symptomatic people seek medication examination. Hence all of them has inflammation.
How long will it take to recover? that's depending on the damage done. The younger you are, the higher chance of you have early recovery.
Some damage can be permanent and may never recover. But, with H. pylori eradicated, we believe your gastric cancer risk will not continue to rise
